跳转到主内容
The third generation of the Apple iPad, released on March 16, 2012. Full 4G and Wi-Fi model repair guides. Repairs require heat and careful prying. Model numbers: A1416, A1430, and A1403.
Touch not working after replacing screen
I replaced the digitizer only an iPad 3rd generation. I haven't sealed it. It does come on and Siri comes on but the touch isn't working. Help!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
If possible, remove the new digitizer, and test the old digitizer to make sure it's not an issue with the iPad's logic board.
If the old one works, you'll know you need to replace the new digitizer as it would likely be defective.
这个答案有帮助吗?
得分 0
2条评论:
I can't put the old one back on because it shattered.
完成的
I should say I shattered it when I took it off. it only had a crack prior to my replacing it :(
完成的
添加一条评论
添加你的答案
Donna 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 132
