跳转到主内容
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
CPU Upgrade to future intel processors
Good day,
Those the motherboard in the intel imac 21.5" support future iterations of intel processors?
I do a lot of audio work using my imac. I would like to have the option to upgrade the processor and ram (which I know the motherboard could now take up to 16 gigs) as needed in the future.
I would ideally like to upgrade to to the i7 processor currently offered in the 27" model. Is it at all possible?
-Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Here is a guide on how to remove the CPU
iMac Intel 21.5" EMC 2308 CPU Replacement
As far as upgrading the CPU you the i7 is not possible because the current CPU and the i7 have different sockets. You could try upgrading to a CPU with the same socket as the Core 2 duo currently in the iMac here are the specs for the core 2 Duo.
http://ark.intel.com/Product.aspx?id=414...
To be on the safe side I would probably get a CPU with the same Max TDP (wattage) and voltage range as the Core 2 Duo.
The best LGA775 socket, 65W TDP, 0.8500V-1.3625V voltage range CPU out there is this one:
Core 2 Quad Q9550S (Yorkfield), spec# SLGAE (E0) Here is a list of the CPU's:
http://en.wikipedia.org/wiki/List_of_Int...
This s not an i7 but it will definitely outperform the Core 2 Duo. You will probably have to reinstall Mac OS-X AND OR come up with a driver somehow to accept this CPU since Apple never made a Mac with this CPU.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Edgar Tejada 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 3,075
