跳转到主内容
A tablet released by Hisense in 2014, identified by model number E2281.
36 个问题 查看全部
How do I replace the broken digitizer on my Hisesnse Sero 8?
(I'm a first-timer here).
Hello everyone, I dropped my Sero 8 tablet from desk height (cracking the digitizer in the process). When I turn it on, I can see my lock screen clearly (therefore the LCD must be fine), but the digitizer doesn't pick up input anywhere on the screen.
I think I know how to remove the broken digitizer, but how do I put on a new one?
And could someone provide a summary of removing the digitizer for the Sero 8 just so I can be sure I know how to do it?
What tools do I need? What tools would be useful but not essential? I know I need a blow dryer, and dinky little screwdrivers (what kind/size though?), some things to pry the screen off (and some things to put between the digitizer and the LCD prevent the adhesive from re-adhering)...
Anyone have recommendations for what I buy?
Thanks,
-Charlie
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
5条评论
Someone please help me! I don't know what to do!
完成的
Hi,
I can't find any info about a Sero 8 digitizer replacement procedure. Here is a link which shows how to do a Sero 7 Pro digitizer replacement. It may be of some help, no guarantees that the Sero 8 will be the same. The disclaimer states that it is NOT an easy repair. Your decision.
https://www.youtube.com/watch?v=JtMyKmvD...
完成的
anyone else got some info?
完成的
Alright, I'm buying another tablet.
完成的
Well, I’ll be planning on repairing this same device in the future and show details in years.
完成的
添加一条评论
2个答案
最有帮助的答案
It would be great if you could contribute a screen replacement to the existing guides for this model. The current guides serve as a good reference point and the several youtuve videos for the Sero 7 can supplement any areas you may be concerned about.
Hisense Sero 7 Pro glass only screen repair as recommended by @jayeff
Hisense E270BSA - Digiter / Front Glass Replacement - Instructional Video
Hisense Sero 7 Pro Tablet Part 2 Taken Apart
As far as the tools you would need, those shown in the first video were:
Set of Picks
[关联产品丢失或禁用: IF145-000]
Spudgers
Tweezers - Pro / ESD / Blunt
Double-sided adhesive tape
Philips and flat head screw drivers
The links for the tools are those on iFixit for easy reference, but you can source these locally as well.
Since your current digitizer is broken, I recommend that you use packaging tape over the existing cracked digitizer to minimize small parts from breaking off. This may make it possible to remove it as one piece.
Spudger图片
产品
Spudger
$3.99
Tweezers图片
产品
iFixit Opening Picks (Set of 6)图片
产品
这个答案有帮助吗?
得分 2
添加一条评论
Look on google it normally gives a dismantle process of most things
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Charlie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 1,107
