跳转到主内容
How to remove the original RAM?
I want to upgrade my memory into 2.5G,but problem seems they are not compatible. while added the additional 2G memory the Mac shattered down very ofthen .Besides the memory mode I bought is the required one,thus I accept the solution to remove the original 512M ,unfortinately it's soldered with the mother board.How to do it then?any tools necessary?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
make sure the RAM you are using meets the specs listed in this Apple Knowledge Base article:
http://support.apple.com/kb/HT2266
PowerPC G5 processors are very finicky about RAM, make sure you are using quality RAM with a lifetime warranty - don't buy the cheapest module out there. Sounds like your machine just doesn't like the 2GB module... hopefully you can return it? If so try a different brand: OWC, Crucial, EDGE, Kingston all offer RAM which works well with G5 processors.
You cannot remove the internal 512MB module - it is surface mount soldered onto the logic board.
这个答案有帮助吗?
得分 1
添加一条评论
Thanks David,
I ordered the exact same standard as it required.Here's what the seller described,
http://cgi.ebay.com/NEW-2GB-Apple-iMac-G...
It's a Kingston for iMac533 model.
Will it depend on the operation system?Mine's still in Tiger
这个答案有帮助吗?
得分 0
2条评论:
no the version of OS X won't have any impact on whether the memory you bought works or not. To me, from the vendor's page, it's not 100% clear what the actual specs of the RAM are - you're basically trusting the vendor is selling you the right kind. Personally I would buy from a vendor that lists the actual technical specs and make sure they match the specs that David pointed to above
完成的
Oh,I got the lifetime warranty paper together with the product and the model sign tagged on the covery is KTA-iMac533/2G which said quite compatible to iMac G5... so confused , thanks anyway.
完成的
添加一条评论
添加你的答案
talentsky724 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 2,083
