跳转到主内容
加入维修社区 - 创建账户
LG G4 于 2015 年 6 月初在美国发布,它一如既往地专注于高端规格和精致的时尚感,使其在高端智能手机市场中脱颖而出。根据运营商销售或无锁版(美国或国际版),该手机的每个版本都有不同的型号。众所周知,部分 LG G4 存在无限重启问题。
LG G4 Camera won't focus
A few days ago I dropped my phone and now my camera refuses to focus. Even on manual mode when I try to adjust the focus it stays at a constant macro focus- everything is always blurry!
Any ideas on how to fix this? I've tried replacing the rear housing but that didn't do anything.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 8
添加一条评论
4个答案
已选择的解决方案
The camera connector may be loosen as it is droped from the height. Try to connector the camera flex again. If that still can't help, your camera may be broken. Here is how to remove the back camera: LG G4 后置摄像头更换
这个答案有帮助吗?
得分 5
1条评论:
Hey, I have the same issue with my LG G4 camera. I want to do what you suggested (connect the camera flex again), but I have no idea how to do it. Can you help?
由完成的
添加一条评论
It is very easy to re conect the flex cable, first remove the battery cover then remove the or 10 screws and pull of the cover and you should see the flex cable beside the camera the use a plastic tool to disconnect the flex cable and reconnect and push hard until you hear a click
这个答案有帮助吗?
得分 0
添加一条评论
Note: On my phone I found 11 screws on the cover.
这个答案有帮助吗?
得分 0
添加一条评论
Camera is damaged you nd a camera replacement
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
sdustinnguyen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 15
总计 9,230
