跳转到主内容
问题已关闭
Logic Board Swap A1229 in a A1212
I have mint A1212 17inch MacBook Pro. It is not capable to update to El Capitan.
I also have a beat up A1229 that has El Capitan on it.
Can I put a A1229 Logic Board in a A1212?
Then I could upgrade to El Capitan.
Greg
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
No you have LED screen in A1229 and LCD in 1212 .
这个答案有帮助吗?
得分 0
1条评论:
To correct John's answer here: The backlight in your older unit uses CFL's and your newer unit uses LED's. The circuitry which drives these different light sources is very different. Sadly, you can't swap the logic boards between then systems. In any case both are LCD displays.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 174
