跳转到主内容
加入维修社区 - 创建账户
苹果官方于2015年9月25日正式发售iPhone 6s的维修信息和指南。机型:A1688、A1633
Need to restore iPhone but iTunes backup password forgotten
I need to restore my iPhone 6S with iTunes. The backup file was encrypted so I tried a few password sets commonly used by myself. However, none of them was correct. For my case, is it possible recover my iPhone with that password-locked iTunes backup file?
thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 15
4条评论
You can’t restore an encrypted backup without its password. With iOS 11 or later, you can make a new encrypted backup of your device by resetting the password. Here’s what to do:
On your iOS device, go to Settings > General > Reset.
Tap Reset All Settings and enter your iOS passcode.
Follow the steps to reset your settings. This won't affect your user data or passwords, but it will reset settings like display brightness, Home screen layout, and wallpaper. It also removes your encrypted backup password.
Connect your device to iTunes again and create a new encrypted backup.
You won't be able to use previous encrypted backups, but you can back up your current data using iTunes and setting a new backup password.
If you have a device with iOS 10 or earlier, you can't reset the password. In this case, try the following:
If someone else set up your device, ask them for the password.
Use an iCloud backup instead of iTunes. If you don't have an iCloud backup, you can make one.
Try using an older iTunes backup.
完成的
try your computer pw, it works for me.
完成的
A few things that helped me:
- Make sure the iOS on the phone you are restore TO is NOT older than the iOS you backed up from. This causes a long-winded "backup is corrupt or incompatible" error message that looks A LOT like the "wrong password" error message.
- Use Keychain Access app on your computer to look for iphone backup password.
- And do that on the FIRST computer you ever backed up your phone to, maybe not your current one.
- In Itunes, Preferences, Devices you can see a list of backups. Pad lock = encrypted.
Good luck!
完成的
Well I did follow same thing Son Tran. I did reset all settings and took the backup as I did not remember my iPhone back up password. That lend me in another problem which seems to be IOS bug where data should not be encrypted but still it is and that too without password.
I have contacted Decipher Tools Support team suggests that iOS backup bug which is turning off the encryption with a settings reset (a recent feature added in the middle of iOS 11) ends up creating an encrypted backup, but without the encryption keys. (More specifically, it refreshes some of the files updating the lack of encryption, but doesn't rewrite the older files without encryption as it should.)
So any suggestion to get back the data?
完成的
添加一条评论
13个答案
已选择的解决方案
the backup files is password -protected, you have to enter the correct password, or crack your password by some software. like iSeePassword iTunes backup password recovery tool, it's not free but works.
这个答案有帮助吗?
得分 6
9条评论:
Did you use this before? Usually, my password is kind of simple, i am sure about it. Anyway, thanks for the recommendation, i will check it out.
完成的
I uninstalled the software, reinstalled it and in 2 hours 15 minutes I retrieved my password, thanks for much!
完成的
I've been trying for about three hours no. I have no progress. Did you have any hint as to what your password may be? ( I mean numbers/words/special characters)
完成的
i hv lose my aplle id u hv any solution ????
完成的
How much do they bite you for this?
完成的
显示更多的4条评论
添加一条评论
I had the same problem. Tried everything that I could think of in 3 hours. Finally one pass word comes in mine, i tried my luck and it really work: the first password that I set to lock my phone the first time I started to use that iPhone. It was 3 years ago and I changed a lot of different passwords after it, but the iTunes only recognises your phone by the first password that u set with it. Hope it helps!
这个答案有帮助吗?
得分 6
6条评论:
happened to me as well, after writing down all the possible password combinations, the one that worked for me was the first iTunes account's pass I ever had...pretty weird, I never encrypt those backups and suddenly when swapping phones this afternoon, somehow my backup got encrypted, but now is ok.
_\m/
完成的
Happened to me as well, tried everything. after reading this comment I realized that the password options for iPhone Gen changed over from 4 to 6.
完成的
yes. you saved my life. this works. just try to remember the first password you ever set on your ipgone
完成的
It really works with the help of the tool to recover iTunes password . I already have used it to get back my backup password, and if you remember more of your backup password, you will have more chance and save more time to recover backup password.
完成的
many thanks, i remember my first pw, eww 8 years before...
完成的
显示更多的1条评论
添加一条评论
No unless you figure out the password. The backup file is not "password-locked", it is actually fully encrypted, you can't beat encryption.
这个答案有帮助吗?
得分 3
1条评论:
yeah, i knew it. i am still working on how to get the password back. thank u
完成的
添加一条评论
I also faced the problem forgot iTunes backup password for iPhone 6. But fortunately I find forgotten iTunes backup password out at last with a third-party iTunes backup password recovery tool, iSunshare iTunes Password Genius. It is recommended by my best friend. So I tried it, and unbelievably it really helped me and fast recovered iTunes backup password.
In the process, I find the as long as you find the password to open file Manifest.plist, you can restore your iPhone from iTunes backup successfully. Therefore, no matter your iTunes backup is saved on Mac or Windows computer, you can copy the Manifest.plist to Windows computer, and run iTunes Password Genius to recover iTunes backup forgotten password in few seconds.
Nothing needed to be worried about, especially password recovery efficiency and backup safety.
Just get the iTunes backup password recovery tool and learn how to use it. http://www.isunshare.com/itunes-password...
Note: Besides iTunes backup, actually you also could restore your iPhone 6S from iCloud backup. Or restore iPhone data with iOS Data Genius, which also provides two ways to restore data, iOS devices and iTunes backup. If you choose iTunes backup, you would also need iTunes backup password recovered with iTunes Password Genius.
这个答案有帮助吗?
得分 2
1条评论:
Same here I forget iTunes pw and I try isunshare.. it run over 50 days 24/24 per day but no successful . Finally I give up
完成的
添加一条评论
Looking for a way to restore iPhone but iTunes backup password forgotten?You can Restore encrypted iPhone backup with iPhone data recovery, retrieve lost iPhone data by extracting encrypted iPhone/iTunes backup.
Read More: How to Restore Encrypted iPhone from iTunes Backup
这个答案有帮助吗?
得分 1
添加一条评论
See, I have also faced the same issue with my iTunes. I forgot my iTunes login password. To recover password I applied some tricks but no result. Then I need to restore my iPhone. I want to Restore iPhone Without Updating. Someone help me, please!!
这个答案有帮助吗?
得分 1
添加一条评论
Hey I was having the same problem and I put in the original password that I had used for my iTunes account and it worked. Maybe it can work for you too!
There is also another tool (UUkeys iTunes backup unlocker) which can help you unlock iTunes backup file, most users used it to recover their forgotten password.
这个答案有帮助吗?
得分 0
添加一条评论
Hello! If your password is not too strong, you can try to recover it using the iTunes Password Refixer utility.
这个答案有帮助吗?
得分 0
添加一条评论
You can reset it if you forgot iTunes password which is also known as Apple ID password. There are several solutions to reset password: via iforgot.apple.com or iCloud resetting. Optionally, you don't have to use iTunes backup. Just try other backup solutions. However, since iTunes and iCloud share the same password, the way of restoring via iCloud does not work either. But with the help of an iOS data recovery app, you can restore WhatsApp messages, contacts, music, photos, videos, notes, calendars and more from the iPhone without using backup.
这个答案有帮助吗?
得分 0
添加一条评论
Try several times if you can. If not, you can use some password recovery software, search on Google.
这个答案有帮助吗?
得分 0
添加一条评论
Is the iTunes backup password the same your Apple ID password? If you forgot Apple ID password, you can recover Apple ID password via Email Address or Security Questions
1. Open your brows and navigate the webpage to https://iforgot.apple.com/.
2. Input your Apple ID that contains an registered email address which is associated with your Apple or iCloud account.
3. Finish the CAPTCHA characters verification, tap "Continue".
For more info, you can refer to: https://www.cfone.net/what-if-i-forgot-a...
这个答案有帮助吗?
得分 0
添加一条评论
Yes, @harry_bvm gave a more complete solution. You only have two choices: First, abandon this iTunes backup that has forgotten the password, create a new iTunes backup or get an iCloud backup. Second, use the unlock tool to solve iTunes backup password forgotten.
这个答案有帮助吗?
得分 0
添加一条评论
Although legally you may not be required to have a urology specialist with the consent of your wife or partner, vasectomy cost (or any contraceptive choice) should be best decided as a couple. This is one decision that you may not want to make any scalpel vasectomy. Your partner can come to the consultation visit with urology vasectomy near me so that you can both ask questions about the men and women urologist specialists.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
zenbiad 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 28
总计 229,477
