跳转到主内容
The HP Pavilion dv3, released April 2009, is part of HP's dv series. The dv3 may have various options for specific components, but comes standard with a 13.3 inch screen and weighs 5.5 pounds. The dv3 is easy to disassemble, due to its simplistic internal layout, and will most likely just require a screwdriver or two.
Why is it not in english language
Laptop is not in English
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Whats the operating system?
完成的
添加一条评论
1个答案
已选择的解决方案
Get into the settings or control panel depending on which version of windows you have .Go to time and language and select language of choice . To help find what you need use google translate to help navigate the language its presently using. Hope this helps
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
janetgildein69 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 130
