跳转到主内容
The Canon AE-1 is a 35 mm single-lens reflex (SLR) film camera for use with interchangeable lenses.
Why does the mirror lock up after shutter is fired?
The advance lever works, and the shutter button does too, but once I fire the shutter, the mirror stays up (it's like im doing a long exposure). So I remove the 6v battery and right away the mirror drops, but then I place the battery back in and it happens all over again.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
I do to at slower speed settings and I wonder if it is a lube issue since I barely use this oldie..
Will post if I ever get a fix..
这个答案有帮助吗?
得分 0
1条评论:
Did you ever fix? Having same problem!
完成的
添加一条评论
There’s a wire inside the top cover. It links the speed dial with another dial and a spring located in the left side under the rewind lever. It it’s either broken or loose (spring tension is lost or it went out from the pulleys) the speed will always go to infinity and the mirror wont come down until reseting the signal. You have to replace the wire if broken or set it tight again if its loose.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ana 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 27
总计 2,684
