跳转到主内容
The HTC One (codenamed M7) is HTC's 2013 flagship smartphone. It features a seamlessly designed unibody aluminum frame, large dual front-facing speakers, and a 4.7-inch 1080p display.
Why won't my HTC One connect to my computer?
My phone charges fine, but I can't connect it to a computer to offload files.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
5条评论
Hi,
Have you tried the following : a different USB cable, a different USB port on your PC, a different PC?
完成的
different USB pot
完成的
no success despite installed htc sync manager as per notification over my phone
完成的
完成的
I have tried different cables and a different port on my PC and it still can't find the program
完成的
添加一条评论
2个答案
最有帮助的答案
There are several reasons:
1. The USB cable might not work for transferring, it could only help you charge. Then you should change a cable.
2. You didn't enable USB debugging mode. You can go to "Settings "> "Developer options"> turn on "Developer options" and check "USB debugging"
3. If those don't help, you might need a wireless file transfer app to help you transfer files from Android to PC.
这个答案有帮助吗?
得分 2
添加一条评论
you need the free HTC software, it manages data transfer
这个答案有帮助吗?
得分 1
2条评论:
Developer options
完成的
how to get free HTC software
完成的
添加一条评论
添加你的答案
Nick R 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 17,282
