跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Searching/no service after screenreplacement
I had a customer that repaired a iPhone6 screen.
Everything worked fine.
They came back after 1 month, having no service or its just searching.
After i replaced the charge port the i6 got service, i handed out then phone to the customer.
Got a call after 10 minutes and they got the same problem again.
I have tried everything following:
Changed chargeport.
Reset network settings.
Reset Phone.
Tried different simcards.
Checked for water damage. (There were none)
Cleaned the motherboard with ISO.
Date and time is correct.
Correct country is set.
Anyone had any problem like this before and know how to fix this?
// Worried Service technician.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Have you tried using a sim you know is valid? I know you said you tried different cards. But are they valid? Another thing that maybe, updating the iOS?
这个答案有帮助吗?
得分 1
2条评论:
All sim cards that ive tried is valid.
After i replaced charging port it worked for 15 minutes and then it stopped working again, going back to "No service".
It´s updated to IOS 9.1.
完成的
Sounds like you've really covered your bases. I'm guessing after only one month, they're still under whatever warranty you carry, for repairs. Even though it sounds like their fault
完成的
添加一条评论
添加你的答案
MrSir 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 484
