跳转到主内容
一部诺基亚品牌的Windows phone,2013年4月发布。
81 个问题 查看全部
Cant open any applications even after hard rest
Phone was working pretty well since the last three years. Last night suddenly, all of my applications stopped working. Even after hard reset and again downloading all of the same applications they won't work. What could be the matter ??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 8
13条评论
Hi,
Did you update any apps or the phone just before it stopped? If so can you remember which app? If so uninstall it and see how it now goes. If you didn't do anything like that, when you hard reset, did the preloaded apps (the ones that came with the phone) work? The phone must be working of a fashion, you said that you downloaded all of the same apps again. Maybe one app has again altered something on installation and that has affected the rest. Just an idea. Maybe you could try to hard reset again. Check that the phone works and that the apps already installed work. Then start downloading your apps one at a time and trying them. When you are satisfied do the next one etc. Long process but maybe the only way to find out.
完成的
1.I didn't update any app or my phone.
2.The preloaded aren't working either. I did a hard reset and downloaded a completely new app. But that new app is also not working.
3.I uninstalled all the same apps again and did a hard reset again. And downloaded a new app. But... same problem.
4. WhatsApp, OneDrive, Music Player,Video,etc. aren't working (after two hard resets)
完成的
Hi,
Is this link of any help to you?
http://www.microsoft.com/en-au/mobile/su...
完成的
I'll try that way and revert back soon :)
完成的
thank you so much :d :d :d it worked !!!
完成的
显示更多的8条评论
添加一条评论
3个答案
最有帮助的答案
Are the Phone in SAFE MODE ??? App are installed in SD memory Card or In Phone Storage ?
这个答案有帮助吗?
得分 1
1条评论:
Yes my phone in safe mode And app is install in phone storage my name is Rajat
完成的
添加一条评论
Sounds like a software issue.
Try doing a hard reset using the following software
https://support.microsoft.com/en-gb/help...
这个答案有帮助吗?
得分 0
添加一条评论
I will try plugging in the wall and doing the hard drive hard reset
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
rohiet bhoslay 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 11
总计 13,191
