跳转到主内容
Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
73 个问题 查看全部
问题已关闭
Ipad2 adhesive problem with digitizer
Hello i recently bought a Ipad 2 digitizer and reapplied it and it will not stay on. I am going to take it back off and the lcd out to try cleaning the metal surface better. Should the adhesive thats already on the digitizer work even tho i already tried to apply it or should i somehow take it off and re apply a new adhesive??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
I am going to assume you are talking about the Glass and digi together. If so and the glass is falling off, i would take off the old adhesive and use alcohol to clean the metal. With a clean surface it should stick better. If it is still falling off you can use some super glue around the frame to help keep it in place.
这个答案有帮助吗?
得分 0
添加一条评论
Sounds like it was supplied with poor adhesive. Your best option is to use 3M Heat activated tape which most repairers use on their repairs. It is easily removed with heat for future repairs. Don't use super glue.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 51
