跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
iPhone doesn't load anymore
Hey iFixit community,
I have a problem with an iPhones 5s. It was fallen into an toilet -.-
After that it didn't start anymore, so I opened it and dry it. After that I claend the motherboard with 100% alcohol and changed the Battery with a new one. So I was ablte to start the phone. Everything works fine, expect the homebutton(fingerprint is working), microphone and connector. So I also swaped the whole dock connector. Now the phone still not recharge -.- The computer doesn't get a signal, too.
If I turn it of and plug in the Cable the iphone restart automatically , so i think the new dock connector is working. But the recharge, homebutton and microphone won't work.
I only have 20% battery left.
Do you have an idea, how to fix that issue? :)
Thank you very very much,
Felix
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hello Felix,
Finding fault will be complicated as you phone is liquid damaged. find the below image and find the location, remove the EMI shield
Clean the area around U2 and re-hot using BGA reworking station
let the logic board cool and re-fix the connectors and check whether phone begin to charge as normal. if the fault remain same change the U2 chip
Note : Replacing BGA components you may need sound BGA reworking skills
Good luck !
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Felix 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 122
