跳转到主内容
初代iPhone(又称iPhone 2G)。型号为 A1203,存储容量有4GB、8GB、16GB可选,机身颜色仅有黑色搭配金属铝。维修初代iPhone是容易的,需要耐心,一些工具和焊接技术。
224 个问题 查看全部
One of the antenna cables cutted and solded. No WiFi connectivity.
Hello.
Few days ago, the sim tray of mi old iPhone stuck inside, so I had to disassemble it.
I had a lot of problems to do it, and, in the proccess I cut one of the antenna cables, the one that is connected in the middle of the antenna ribbon sheet.
Edited: Read the actual situation below the first image.
The cable is cutted very closed to the metal cable support in the side of the phone (see the arrow in the photo), and I'm afraid that if the cable make contact with the support, the comunications board (or something else) could be damaged.
What do you think there is the best solution for this problem? maybe cut the cable in the other side of the metal support, and replace this fragment with a new cable?
Thank you very much for the help!
Edited:
I've read that the two wired are "the same", they are connected to each other and connect the comunications board with the antenna ribbon and the rear case.
I've solder the cutted cable and I've check with a tester the connectivity between the comunications board (1 and 2), the antenna ribbon (the two connectors) (3 and 4) and the rear case (5), all ok. The points are marked in the image.
See the image in full size
The problem is that I don't have WiFi connectivity. The GSM coverage is fine, but none the Wifi.
I have the phone disassemble, and I have connected the parts with a wire.
Any suggestions about the Wifi coverage?
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
Please, can anybody tell me anything about my problem? :(
完成的
+ for a well stated question and illustrations.
完成的
添加一条评论
3个答案
已选择的解决方案
agree, these are made without using soldering. cannot remember correct phrazeing, basically, solder in this case works as shielding. means, no signal gets through. you need to get a new set of antennas. these cost about 3USD, ebay...
这个答案有帮助吗?
得分 1
3条评论:
Thank you very much for your answers, I'll buy a replacement cable set.
But... I think that the antenna cable is solded to the metalic support under the battery, am I right?
完成的
You may try just cutting off the ends of the broken cable and running the new cable along side the remains of the old one. You shouldn't need to solder the new cable along the middle. Perhaps just use some thin tape to hold it in place.
完成的
Last weekend I received the new cable and replaced the broken one.
WiFi now works perfect.
Thank you for the answers!
完成的
添加一条评论
最有帮助的答案
These are coaxial cables. They have an inner conductor that carries the signal plus an outer ground shield. Your best bet is to completely replace the broken cable.
这个答案有帮助吗?
得分 4
1条评论:
完成的
添加一条评论
Any tips on how you did the replacement finally?
Did you remove the broken wire or not?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jorgeoa 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 11
总计 3,237
