跳转到主内容
加入维修社区 - 创建账户
宏碁 Aspire 系列笔记本电脑的维修指南和支持,适合家庭和企业使用。
touchpad gets stuck and getting WHEA error
aspire E 11 (ES1-111M)
received error twice (computer just shut down) and my touchpad randomly freezes every so often. it works with an external mouse though. what should I do?
found this driver page but now sure which one I need
http://us.acer.com/ac/en/US/content/driv...
thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
If you have no WHEA problems when using a mouse, it may be that your touchpad either has a hardware problem or a software problem.
A software problem is usually solved by updating the drivers for the touchpad to the latest version.
Depending on whether you have Win10 or Win8.1 will depend on which drivers you need to install.
If you have Win10 it is easy because there is only one choice -Synaptics.
If you have Win8.1 you need to find out the name of your touchpad manufacturer to know which driver to download, because there are two alternatives -Elantech and Synaptics.
To find out which one you need, you have to go into Device Manager in your laptop.
Press Win key and x key together, ( Win + x), click Control panel, click Device Manager, Device Manager window should open. Scroll down to Mice and other pointing devices, expand tree your touchpad should be listed here. It will either be Elantech or Synaptics.
Using the link provided in your question, enter Aspire ES1 in the Search by product model box, then click on Aspire ES1-111M, (you probably know this already). Select the appropriate OS for your laptop. If Win10 download the Synaptics Touchpad driver and install in your laptop. If you have Win8.1 installed download the appropriate driver (name as found in Device Manager - Elantech or Synaptics) and install in your laptop.
Hopefully this will solve your problem.
If you need to know how to install the drivers please advise.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
hr1 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 536
