跳转到主内容
Repair and disassembly guides for Christmas lights.
37 个问题 查看全部
1000 Low dim light not bright twinklers
My husband and I have spent the entire weekend stringing lights around the house and through the yards, front and back we set up several blow up displays and some standing ornaments in the yard all with lights. My husband fancys himself as a handy man and for the most part he is.
We have at least 50 or more strings of lights on the house and garage and garden shed. There is maybe 20 or strings of lights on the trees around the yard and all the ornaments and blow ups have lights. We bought high end outdoor power bars and ran them all to a control panel an electrician friend had built for us.This in turn is wired into the main fuse panel in the garage which has heavy power as my husband puts it . He has a work shop in the garage with lots of power tools. So the question of power should not be a problem but it is.
Heres our problem when we turn on the lights they are very dim . We have tried shortening the extension cords taking off lights we've tried cutting the number of lights down but the only thing that seems to work is taking the LED lights out of the equation. when we take out the led and leave only the older strings of lights everything works fine but when we use the newer ones it all dims out. hes out there now trying to hook up only the led to see if they will work alone has anyone had this problem and can you tell us what we can do to run both the old lights and the new.
UPDATE :
Paul's still out in the yard without any luck yet hes tried the control panel removal , didn't work, he's now checking each strand of lights to see if there's just a bad strand. will keep you posted please more ideas would be appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 7
4条评论
Wow and again wow can you post a picture when you have it figured out
完成的
Im with Robert here post a pic
完成的
did you get your lights going?
完成的
stopped lat last night and are checking strings this morning
完成的
添加一条评论
3个答案
已选择的解决方案
Holy blinkin lights are you sure your names not Clark Griswold
That's a lot of Christmas lights
The leds should work fine with the old lights If anything is at fault start at your control panel take it out of the equation and just run your cords into the garage and use the outlets in there if Clark has heavy power in there
Hope this helps and Merry Christmas
这个答案有帮助吗?
得分 8
4条评论:
Paul not Clark and we do it for the Grandkids and yes it is a little overkill. Thanks for the thought Ill suggest it to him when hes done with what hes trying now.
完成的
Have you tried the lightswitch in the garage? ;)
完成的
Another thing you may want to check is if you cut or punctured any cord in the installation. did you happen to use a staple gun to mount the cords
完成的
We did staple some cords and we have it all working now. We're not really sure what we did to fix the problem . it just working . we did take out a blowup ornament but it works by itself fine
完成的
添加一条评论
We had the same problem last year when we put our lights up although we didnt have anywhere near that many lights. we had 1 bad strand of led that just sorta glowed real dim and when we took then out all the other lights that were in the same run of lights worked fine Merry Christmas .
P.S. don't forget to check the lightswitch in the garage Hahahaha
这个答案有帮助吗?
得分 5
1条评论:
Ive heard of this were the whole line of lights is bad or has a short in it
完成的
添加一条评论
My Husband makes lights each year an bad bulbs make not to work so look at all to bulbs. This is very many lights
这个答案有帮助吗?
得分 4
2条评论:
all i ever do is change bulbs
完成的
Changing of the bulbs is a christmas tradition
完成的
添加一条评论
添加你的答案
Sandy Frisco 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 10
过去 30 天: 20
总计 9,567
