跳转到主内容
Repair guides and support for smartwatches produced by Fitbit.
628 个问题 查看全部
Replacement part for fitbit charge HR , back piece of the displa
Hi
the small plastic/metal piece that houses the side button and holds the charge cable in place when plugged in to charge is broken, so now I cant charge my fitbit, and the side button has fallen off, I know I can get a replacement from fitbit if I am still under warranty, but I would like to know if I can by a replacement piece instead.
Model: Fitbit Charge HR
回答此问题 我也有这个问题
这是一个好问题吗?
得分 25
22条评论
Me too, please help. I have and love my fitbit for 8 months and am now fitbitless - because it will not charge properly. Help!
完成的
Just contact the Fitbit support and they'll send you a new one
完成的
Me too. The cover came off after charging it and the tiny little button flew out somewhere. I searched for an hour and that thing simply vanished.
完成的
me too. i have lost my side button. how can i fix it since over year old
完成的
I did contact the FitBit support team and they where not able to help me with MY fitbit, but did offer 25% off a new one! Really! If I could just get my fixed I would be happy!
完成的
显示更多的17条评论
添加一条评论
15个答案
最有帮助的答案
I have emailed Fitbit filling out their form and sent a picture of the broken part. This is obviously a defect in an otherwise great product. But...you can't buy the replacement part and since my Charger HR is over 45 days old (of course) then the warranty will be an issue.
Waiting to hear back from them to see if they're going to replace the one piece at no charge. We shall see.
这个答案有帮助吗?
得分 3
4条评论:
Donna
If you purchased your fitbit less than a year ago, they will replace it for you (may be a refurbished item)
I called / emailed fitbit and they sent me another one.
完成的
I have the same problem and I am out of warranty. I was able to put an elastic around and keep that piece on & it works perfectly. I just called to ask for a replacement piece and how to fix it and they said they have no way to repair and no way to send out parts. They only offered me 25% off of a new item........
Big deal! I have one that can work perfectly With a simple new piece of little metal. Their option is I throw it out & buy a new one !!!
and what happens when the new one doesn't work! The cycle continues?!!!
Forget it, I'm going to research a new option and make sure "other" product is repairable!
完成的
Every owner of a HR is having a fit over there bit and with the new HR out. Fitbit should exchange all old HR out for the new ones. Everyone of us rave to our friends how much we like and love all the data we get from it. It also could be easy to say the competitors are much better.
完成的
I am probably at the wrong place for this . I enjoy my fitbit hr however the band is completlet dismandle. can I get a band to fit or do I need a new fitbit please let me know. Angie
完成的
添加一条评论
I had this part break off too - Fitbit doesn't sell parts and mine is over a year old now, so I fixed it myself with a small piece of hard plastic for the button and Sugru for the case, working very well so far and if you didn't know how the button looked before you wouldn't be able to tell by looking at it..
这个答案有帮助吗?
得分 2
2条评论:
I thought about using Sugru, but didn't have any at the time... like I mentioned above, if the fitbit is not more than a year old, they will replace it for you as I believe they are aware of the faulty part.
完成的
Can you post a picture. I never saw the piece so don't know what it should look like.
完成的
添加一条评论
For any of you still searching or that may run across this thread, I am offering a solution since fitbit has not. If the piece has broken or is lost this will fix the issue. I am selling them on ebay, you just superglue it on. It is a single piece with an integrated button.
http://www.ebay.com/itm/282236030676
这个答案有帮助吗?
得分 1
5条评论:
Do you ship it to India as well?
完成的
Do you ship to Australia?
完成的
I am doing international shipping from ebay now.
完成的
I just bought it. Thank you for having an option fairly inexpensive compared to only 25% discount the company is offering for a defective product.
完成的
Do you have the dark purple one? I tried to find it at amazon and ebay but no luck with that specific color.
完成的
添加一条评论
I found the proper clip. It is sold by centralsound for $9.99 on e-bay. I did not know that there are four holes that are filled in from the old broken clip. had to use a small pick to get the ols plastic out for the new clip to work, It is a perfect fit. I also found a person printing the part; it looks rough,
这个答案有帮助吗?
得分 1
添加一条评论
I had the same problem. My tracker was less than an year old and am being sent a replacement. A simple call made thru Fitbit Support. Fast and painless. My replacement tracker is supposed to arrive in 5-7 days.
这个答案有帮助吗?
得分 0
添加一条评论
New to this post. I am also >1 year out and the opposite side of the frame , including the port hole to the charge connection, has come loose. Can't charge device.
About this sugru: are you using it to mold a replacement piece or as an adhesive for existing piece? I'm not clear on the application.
这个答案有帮助吗?
得分 0
添加一条评论
I have the same problem, but my FitBit is over a year old and they will not replace the part.
这个答案有帮助吗?
得分 0
添加一条评论
I had same issue and my fitbit is over a year old. They are offering me 25% discount if I choose to buy new one in exchange of my existing fitbit. I don't like the idea of trading fitbit which is working fine except for one broken part only for 25% discount.
I think I should try and use sugru as well :)
这个答案有帮助吗?
得分 0
添加一条评论
Same thing happened to me. Back plate broke. Have been able to scotch tape button on but charging doesn't work sufficiently. Lasted from August 2015 until February 2017. They offered me 25% discount on Charge 2. I took it as simplest solution for me right now. But not happy about it and totally understand people walking away.
这个答案有帮助吗?
得分 0
2条评论:
My fitbit clip won't charge. I don't want a new one. The old one worked fine. The battery is still good.
完成的
I'm trying to charge my fit bit but there are 2 prongs on my charger but the 2 holes on the charging point on my bracelet has a plastic cover so how can I charge without bending the 2 prongs?
完成的
添加一条评论
Nope they want you to purchase another device, you do get a 25% discount for spending more money for a broken device that works fine it could hold the charger in place.... a $1.00 part.
这个答案有帮助吗?
得分 0
1条评论:
I saw clips being printed and sold on ebay.
完成的
添加一条评论
My Fitbit HR is not working properly as it switch when I wear it , it works few mins then stop working, but when I take it out from my wrist it start to work again. The battery drains faster than before. Is there any solution or I have to get a new one. Of course not Fitbit if this the case. Regards
这个答案有帮助吗?
得分 0
添加一条评论
You can buy a replacement part for the back plastic piece and button for a Fitbit Charge HR at Amazon for $10 plus $5 shipping
https://www.amazon.com/Replacement-Charg...
这个答案有帮助吗?
得分 0
添加一条评论
Fitbit will send you a new FITBIT if you are under warranty. If you are not under warranty you get 25% off for the next Fitbit. Hardly a bargain! They do not sell the part which probably costs less than 1 cent to make. Check online for "Fitbit parts" - I saw a price of $14 but can't vouch for the company.
这个答案有帮助吗?
得分 0
添加一条评论
My small piece on my Fitbit that you push in to tell time and look at steps is out.
这个答案有帮助吗?
得分 0
添加一条评论
I have lost my charge cord. I ordered a new one but it is the wrong size. HELP!
这个答案有帮助吗?
得分 -1
1条评论:
Get the right one
完成的
添加一条评论
添加你的答案
orahmanian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 42,459
