跳转到主内容
加入维修社区 - 创建账户
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
Ipad 2 black screen
My friends Ipad 2 was just displaying the empty battery symbol but would not charge or turn on so I put it into DFU mode when it was attached to the computer and itunes recognised it and started to download an update to restore the ipad, however when the update had finished downloading in itunes nothing happened and now the ipad just has a black screen it is not recognised by the computer or itunes and the button combinations don't do anything. I replaced the digitizer, battery and charging port as he dropped it in some water but after putting the new battery in it worked and it would charge but now it is dead. Does anyone know how to bring it back to life without having to replace the logic board as these are only available second hand and are quite expensive
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Possible water damage to the charging ic.
这个答案有帮助吗?
得分 0
添加一条评论
You need to inspect the motherboard, under any shields, and look for corrosion or damage to the board. You may be able to get it working by cleaning the board with alcohol and/or an ultrasonic cleaner. You may also need to replace some components on the board. Microscope will make inspecting the board easier.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Paul 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 10
总计 232
