跳转到主内容
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
Phone makes strange noise when unlocking
When I go to unlock my GS5 the phone makes a strange a weird beep noise that lasts a second. When I play music the music stops for a second then continues, except when I am playing it on bluetooth speakers after I unlock the phone. Is it a factory reset issue or something more?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Check to see if you have got the Screen Lock Sound enabled.
Go to Settings > Sound > Screen Lock Sound
The Screen lock sound sets the device to sound when you lock or unlock the touch screen.
You'll probably find that this is the reason your music stops when you unlock the phone.
这个答案有帮助吗?
得分 3
2条评论:
If this does not work for you, go to settings> Sound> Screen lock sound and turn it off. once you have done that, go to nfc and payment and switch it on and off. this should solve the problem
完成的
You star, I would never have guessed it was the NFC that was doing it
完成的
添加一条评论
添加你的答案
Peter O 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 12,348
