跳转到主内容
Cobra 29 LTD Classic. 2-way 40 channel CB radio. Features antenna warning indicator, SWR calibration, instant Channel 9, PA capability, dimmer control, switchable noise blanker and RF gain.
8 个问题 查看全部
turns on but wont key up.
My radio turns on but ever time i try to key it, it never read on the meeter or the red light never comes on. It do this every now and then so it works when it wants to i guess. Just would like to fix it since i need it for work. Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
Make sure your radio has a good ground. Preferably chassis. Antenna needs a good ground. Make sure the center plastic grommet is in good shape on antenna that separates the center wire from the outer wire . That would be the main reason why your radio is not getting out.
这个答案有帮助吗?
得分 0
添加一条评论
1) try substituting a different mic or two. The second problem a radio runs into is a broken mic wire down by the plug. The first is an antenna that is not tuned.
2) what is the voltage that is feeding the radio. It should be between 12 and 14 V. If the power is too low for some reason it won’t key-up.
3) ground will be coming from the power wire. Disconnect the coax from the radio to make sure that is the case. Fix the ground wire if necessary. The complaint states that the meter and Tx light are not working. They should work if there was no antenna connected to the radio.
这个答案有帮助吗?
得分 0
添加一条评论
it’s probaly your cobra mic is the pronlem
这个答案有帮助吗?
得分 0
1条评论:
and you can either use a cobra mic and a uniden mic for your cobra cb.
完成的
添加一条评论
添加你的答案
bucky 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 23
过去 30 天: 75
总计 2,545
