跳转到主内容
This Firestrike Elite Blaster was released in 2013. In addition to its plunger activated firing setup, it features laser guided aim. The blaster originally came in blue, white, gray, and orange but a second color scheme features orange, white, and gray.
6 个问题 查看全部
Darts fall out of gunbarrel
The dart is loaded in the gunbarrel, then the three pins at the bottom of the barrel pushes it 2-3 cm out again, thus the gun won't fire effectively.
Any good solutions? Thank you:-)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 9
3条评论
I have the same problem. I'm about to open it up and see what's what but im 16 and not an engineer...good luck to me though!
完成的
lololololooolololololololololollololololololololololololololololololollolololololololo
完成的
lolololoololololololololololololololololololo
完成的
添加一条评论
10个答案
最有帮助的答案
I fixed it! super easy! I have a firestrike and a sharpfire I think 3 darts is not enough so I grabbed some from my sharpfire. they worked for a while but then it stopped working. I was all sad be couse I thought it broke, when I looked closer at the darts I noticed 3 of them had a W and the others had a Y! aperently the elite darts have more groups! the w's are for the firestrike! I hope it helped, sorry if this didnt help.
have a good day!
这个答案有帮助吗?
得分 5
添加一条评论
What is happening is that the darts are getting worn out and are not gripping the barrel enough, I would suggest picking up some cheap knock-off darts and testing it.
这个答案有帮助吗?
得分 4
添加一条评论
This is a common problem with front loading pistols. You have to buy new darts because this happens with worn darts
这个答案有帮助吗?
得分 4
添加一条评论
Here this kid had a perfect answer.. it worked 4 my sons gun.. widening the inside diameter of the round with a pencil or part of tbe gun.. https://m.youtube.com/watch?v=247shtsb0z...
这个答案有帮助吗?
得分 4
2条评论:
I got my nerf guns down from the cupboard after years of non use and had this problem. The pencil works a treat!!! TOP TIP
完成的
Awsome.........
完成的
添加一条评论
The same was happening to my big shock blaster and I found that squashing the darts for 4 seconds will solve this issue.
If it isn't working, try squish harder, I did it so the dart was basically flat.
EDIT:
PS: the darts will drop a bit more, so if you are using this in an actual war, make sure you aim up a bit more. NOTE: they won't drop too much, so don't worry.
这个答案有帮助吗?
得分 3
1条评论:
It worked for me, but i dont think it will be a good idea if you have other guns you want to use your darts for.
完成的
添加一条评论
I took a small section of Scotch tape and wrapped it around the rear end of the Elite darts to give them a bit of extra girth. That did the trick. You may wish to try other types of tape, but you get the idea.
这个答案有帮助吗?
得分 2
添加一条评论
Try opening up your firestrike and there should be a big white tube at the top beside it should be the air restrictor and it should have 3 pins and a spring behind it. Take out the spring and the 3 pins and your good.
这个答案有帮助吗?
得分 1
2条评论:
and put the shell back on and everything
完成的
Don't do this unless you're doing a spring upgrade and need to get every last bit of performance, because this will make your blaster break faster by firing it, especially without a dart in the barrel. Most modern blasters don't need their air restrictor removed.
完成的
添加一条评论
remoove the dart post using plyers
这个答案有帮助吗?
得分 0
添加一条评论
When it happened to me, I simply tried pushing it in further (but not so it gets stuck). Make sure to be careful as when it got stuck, I had to use tweezers and it ripped the plastic off the top. I had to buy new ones but I also agree with Jay s as usually they're just worn out so my method will work but after a while the bullet will get so misformed it won't work and the bullet will be a piece of junk taking up space.
这个答案有帮助吗?
得分 0
添加一条评论
Simple. The darts are worn out. Purchase some off-brands like Waffles or Accufakes prolly on Amazon
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
michaelrefsing 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 19
过去 30 天: 77
总计 25,700
