跳转到主内容
The Plantronics Voyager Legend is a wireless, Bluetooth enabled headset, which is compatible with most cellphones available on the market. Originally released in September, 2013, this device is still popular among a wide variety of users.
Why does my charger or device get hotter when charging?
When the device is plugged into the charger for a normal charging cycle, either the device or the charging adapter gets significantly hotter.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
I have this problem too on my MBPmid 2009. In fact the connecting point gets so hot, it scalds the skin to touch. Turns out the charger is faulty. And continuing to use a faulty charger may have damaged the power board in the MBP too. 1> Use a different original charger to see if problem persists. 2> test on a different machine to see if problem persists.
完成的
添加一条评论
1个答案
已选择的解决方案
There is a malfunction with either the charging station, or the battery could have malfunctioned. Try using another charger to see if the same problem occurs. If the problem is keeps happening, change the battery in the device.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lewis Certain 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 2,314
