跳转到主内容
The HP Pavilion dv2700 is a 14.1'' laptop that was followed by the HP Pavilion dv2700 Special Edition.
Why is my computer not holding a charge?
My computer won't work unless it is connected to the charger. If it is off the charger, the computer will not power up.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
It may be time to change batteries. or the power input port may be partially broken to not letting the battery charge. HP are easy to change as they are usually a plug in on the motherboard and not solder on . Hope this helps
这个答案有帮助吗?
得分 3
添加一条评论
The battery may be a faulty one if it is unable to retain a charge. If there is an issue with the battery then you should replace it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Amanda Urdiales 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 311
