跳转到主内容
Repair information for the Huawei Ascend G7 smartphone. Released in 2014. Model numbers: G7-L01, G7-L03, G7-L11, G7-UL20.
47 个问题 查看全部
Gallery does not let me share photos
Whenever i go to my gallery to try to share a picture it doesnt give me options to share it just opens another app. it opens google pic, and other downloaded apps that i have but never the share options.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
I have an issue that i am using Quickpic gallery for my phone but i cant make it default in app>default app> quickpic i have done that but still my problem do not solve i have huawei y7 prime 2018 kindly tell me wat to do
完成的
添加一条评论
5个答案
已选择的解决方案
I think you need to clear default app settings by going to either:
- Settings > Apps/Applications > Default Applications, and the clear all.
or
- Settings > Apps/Applications > Google+ > Clear Defaults
and redo the previous operation for Picasa and Gallery and then try sharing again.
It should give you the options to choose the app you want to use and give you the options to use same app every time or just once, select just once in order to use a different app every time.
Hope this works!
这个答案有帮助吗?
得分 3
4条评论:
I fixed it, i went to app manager and i put reset app preferences thanks ✌
完成的
Also did the same
Settings
Apps
Manage app
Menu
Reset app preferences
完成的
Thanks this solved it constantly going to Whatsapp as the default; i can now choose as before. :)
完成的
I solved it:
•settings
•manage apps
•menu
•reset app preference
完成的
添加一条评论
What App does it offer to open? An Email app maybe, by attaching the photos to a new email to share them? A social media app (Facebook, Twitter, Instagram..) and creates a new post with the pictures?
Are you trying to share the photos by text? you Gallery app doesn't have a built-in capacity to share photos to someones else's Gallery app. Sharing a photo has to be done either by email, text, bluetooth.. or any other app.
这个答案有帮助吗?
得分 1
5条评论:
I try to share it but it opens picasa and google+ app it doesnt give me the option to pick where i want to share it. When you put share it gives you options like facebook, twitter, email, etc but it does not let me choose it, it opens google +
完成的
What is your current android version? and have you updated all your apps?
完成的
I tried everything with my Samsung S7 and I still cannot share from my gallery. When I try to it goes right back to my home screen with a quick box that says screenshot has unfortunately stopped working. Any ideas on what to do next? I rebooted it several times I've cleared cache. It just started this morning. Thanks for your help
完成的
I am having the same problem with my S7. Am wondering if google photos is blocking my ability to share from gallery and use their app instead?
完成的
I am having a similar problem with my S7. I am not able to share photos from my galary. Any time I try to share a photo, it gives me feedback that my android has unfortunately stopped.
完成的
添加一条评论
I'm having the same issues, I've tried the solutions listed above and they haven't worked
这个答案有帮助吗?
得分 1
1条评论:
Thanks so much for the time.
完成的
添加一条评论
I've tried all these things and no solution. I open gallery, pick a photo, click on the share button…it hesitates, then pops up a fail notice and closes. Works fine if I remove the Facebook app from my phone.
这个答案有帮助吗?
得分 1
添加一条评论
I also cannot share any photos either by fastmail or gmail. I select the photo and Send, but when the email arrives there is never an email attached. This is a key feature for me and I want to solve it.
I just noticed: it is in my Gmail Draft folder without the attachment, so the attachment is not being accessed. I have given Camera all permissions…
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
djelipsis 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 27
总计 22,448
