跳转到主内容
2006年11月, Wii 在北美市场发布。这是任天堂第一款支持直接连接互联网的电视游戏主机。该主机支持在线游戏,以及通过 Wii Shop Channel 分发数字版游戏和媒体内容。
Why can't my Wii console read the disc?
Issue with a Wii RVL-001: The console and controllers can turn on and operate games in memory. I can place a disc into the console. The console attempts to read the disc, then a disc read error pops up. Rebooting does not help. It happens with multiple discs. Is this look like a full DVD drive replacement or something else? Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Before you replace the DVD drive. Try to blow the lens clean with a can of compressed air. If that doesn't work, you can order an official Nintendo Wii cleaning kit. There are also DIY cleaning methods available. Replacing your DVD should be your last resort.
这个答案有帮助吗?
得分 3
1条评论:
Power went off while playing now disc doesn't read
完成的
添加一条评论
If cleaning the lens doesn't work then you may have to replace the drive. But try either A. using compressed air as @jcarm75 said, or B. use a cotton swap and clean it. If all else fails then as a last resort just replace the drive. Hope this helps if not let us know and we can help!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Aspeicher Aspeicher 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 15,347
