跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
问题已关闭
Blue screen boot loop after water damage (no screw damage)
Hello all,
I have an iPhone 5s that had a minute amount of water damage at the battery connector area. Putting a new battery in would allow full function of the device, but I only did that to remove iCloud account and then turned off. I proceeded to water restoration. I removed the shield next to the battery connector and just partly removed the rear shield. I did not see signs of water on any other part but the very end of the logic board. Once I had cleaned off the corrosion with alcohol, ultrasonic cleaner and brush I put the phone partially together with a new battery.
Now the phone began to do a 10-15 second boot loop.
I tried another battery and these were showing the boot screen for probably 30 seconds then would slide transition into the blue screen for probably 1 second and then reboot, and repeat.
I can not get anything out of any other batteries and am curious how removing the corrosion might have made the phone worse..
Does anyone have any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Might be Hard reset will work.
Taking The Phone into DFU mode.
这个答案有帮助吗?
得分 2
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 106
