跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
Home button colour question!
Hi there, I was wandering if it is possible to change the colour of a home button , so I can keep the home button synchronised to the logic board, while changing the colour of the screen and the battery housing.
Any thoughts would be appreciated!!
Many thanks,
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
No your home button needs to stay is original color or else Touch id wont work if you try a diffrent color home button flex only the home button will work but you wont have the fingerprint if you decide to change it turn off your finger prints erase them and install the aftermarket home button. Just be careful when you update or restore you will need the original home button to do that.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
You can get just the cover for the home button thats various colors
http://www.ebay.ca/itm/Silver-5S-Home-bu...
Just remember you have an id system that may not jive with the new button it may be a good idea to test it before gluing the screen back on
这个答案有帮助吗?
得分 4
2条评论:
will the touch ID still work if i change this?
完成的
Not sure sometimes it does sometimes it wont read that's why i suggested trying it before you glue the screen
完成的
添加一条评论
No. Only Apple can reprogram the Touch ID sensor.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Chris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 1,040
