lost windows windows corruption
how can i restore windows
Get the appropriate windows disk for you OS then set your boot menu to boot from the optical drive . Once there select repair firs to see if your problem can be fixed that way if not then you will need to go to advanced and format the drive then reinstall windows. Make sure you have a valid oem key before starting . Hope this helps
这个答案有帮助吗?
Thank you I will have to get Windows disc and try this
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 82
2条评论
What version of Windows is it? How far does it get into boot? Do you know the cause of corruption?
由 gatewaynomad 完成的
Windows 10 I can't get pass utility screen
由 betty alston 完成的
