跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
has anyone solved error 53?
So I have an iphone 6 that has water damage and is bricked beyond help, I'm considering getting a new logic board ($300) vs a new device ($600+). However after many hours of research I've seen several people reaching the same issue, the infamous E53. Has anyone found a solution to this problem or am I doomed to buying a new device? Im fully aware that the home button must be paired to the processing chip, and that "Apple is the only people who have access to that info." Don't tell me that. They buy all their parts from a third party like every other cellphone company etc. So surely there is someone out there who has the magic password so to speak.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Do you still have the original home button flex?
完成的
添加一条评论
2个答案
最有帮助的答案
I have been searching for a way to bypass error 53 (E53), a specific way has yet to be discovered.
As Im still working on the solution, my encounters with E53 have caused me to further explore
the root cause.
Various parties state that the original home button flex must be attached for you to bypass the update.
This is true to a certain extent, as "tricking" the logic board into believing that the original is intact; we may
be able to bypass the lock, which then we can update the settings on the device.
Easier said then done...
I am physically working day and night to figure this out, I am chemical engineer and have been doing
iPhone repairs since the iPhone 4. I can truly say that this is a very different beast, then previous years.
My experience with coding mobile applications, has led me to conclude that the method will require
quite a few tools to successfully carry out the procedure....
I will keep you guys updated.
Please email me at abraham3313@gmail.com as suggestions or extra knowledge is always needed.
这个答案有帮助吗?
得分 1
1条评论:
any headway?
完成的
添加一条评论
Unfortunately not at this stage.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
paxtonhancock 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 240
