跳转到主内容
发布于2015年3月,并在2015年4月10日上市。盖乐世S6是盖乐世家族又一部旗舰机型。其曲面屏版本被称为盖乐世S6 Edge。
487 个问题 查看全部
Samsung galaxy s6 earbuds one side not working
cant explain it very well so im going to show you
could you show me how to teardown the bud?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 17
12条评论
Before you go tearing it apart check to see if your getting it plugged in all the way if you have a case sometimes the case will keep it from plugging in all the way
完成的
I got the problem to did you fix it?
完成的
Mine right bud has very faint audio, basically the same issue.
完成的
ive got the same problem the upper speaker wont work plzz anyone
even if i plug it all the way no result
完成的
hi there
i am just wording could anyone help me i have a pair of Samsung s6 earphones and one is not working can anyone help me asap i really needs them
thanks
完成的
显示更多的7条评论
添加一条评论
20个答案
最有帮助的答案
Sounds nasty but i just blew and sucked the main speaker and they sounded great again!!
这个答案有帮助吗?
得分 12
13条评论:
Not for me...
完成的
me either ..
完成的
it worked for me!
完成的
This was crazy helpful. I thought I was going to have to buy new earbuds!
完成的
Worked for me. Alternating between blowing/sucking for 30-ish seconds and they work like new again.
完成的
显示更多的8条评论
添加一条评论
I just blew into the hole and it just fixed it somehow.
这个答案有帮助吗?
得分 3
添加一条评论
I just blew and sucked the main speaker.. works like a charm
这个答案有帮助吗?
得分 2
3条评论:
Blow and suck and main speaker for 10-20 sec each while alternating. It works for apple earbuds to for future reference
完成的
i could not for the life of me get this stuff stuck in my earbud out by doing that
完成的
nevermind i kept trying and it finally worked
完成的
添加一条评论
The earbuds are made of molded plastic pieces glued together, and attempting to disassemble it would most certainly render the headphones beyond repair.
The jack on your phone doesn't seem to be an issue, since part of the earbud is functional.
Unfortunately, you will have to buy new earbuds.
这个答案有帮助吗?
得分 1
添加一条评论
the right ear phone is not work
这个答案有帮助吗?
得分 1
1条评论:
Same help me fix pls
完成的
添加一条评论
I have two of these earphones and both have weaker or no sound in the right bud. It appears that everyone else has a problem with the right bud as well, and I find it odd that the same bud gets broken with everyone. Im convinced that the earphones themselves are quite bad on the right bud and somehow easier exposed to damage.
I still have my earphones from the galaxy s4, and they work just fine despite being old by now. You'd think new models would be less fragile, but I sit here with two pairs of new, broken earphones, and one pair of working old ones...
这个答案有帮助吗?
得分 1
1条评论:
Same with mines and i got them with my s8. Akg ones. Rigth one has faint audio
完成的
添加一条评论
Blew and sucked my earphones. And were perfectly working.
这个答案有帮助吗?
得分 1
添加一条评论
I trid a combination of both the blowing and suucking aswell as using a toothbrush to try and get in the holes to clean them if that was the case and it worked for me
这个答案有帮助吗?
得分 1
添加一条评论
I have same problem plz help me
这个答案有帮助吗?
得分 0
添加一条评论
Get a lighter and go over the part With no sound this helped me
这个答案有帮助吗?
得分 0
2条评论:
it do not work
完成的
last time i did that i was trying to melt// burn of the wax, ended up with my earbud catching fire, even tho i did fast passes. Not recomended, seeing as it is highly dangerous.
完成的
添加一条评论
How do you fix this problem
这个答案有帮助吗?
得分 0
1条评论:
完成的
添加一条评论
I can hear not sound from both earbuds
这个答案有帮助吗?
得分 0
添加一条评论
Its really easy to fix it i had the same problem one side didn't work so just clean it from inside alright by the time you use the earbud it gets dirty :D so just search how to open it safely and clean it maybe with a tissue paper
这个答案有帮助吗?
得分 0
添加一条评论
I found when I took my earphone for when I had this problem It was impossible to put it back together.
这个答案有帮助吗?
得分 0
添加一条评论
I need help. My earphones is making no sound when plugged in, but when i move the cord around it starts to make a static noise. Plzzzzz help
这个答案有帮助吗?
得分 0
添加一条评论
How do you make the sound come back
这个答案有帮助吗?
得分 0
添加一条评论
The part of the speaker that doesn't work blow on it or keep blowing on it for 30 seconds.
这个答案有帮助吗?
得分 0
添加一条评论
my left side is working the my right one with the microphone does not work at all.
这个答案有帮助吗?
得分 0
添加一条评论
This problem is usually caused by wax blocking the holes in your earbuds. You can use a sewing needle to poke through the holes in the speaker when the headphones aren't in use and you're good to go. The sound will be just like new again!
这个答案有帮助吗?
得分 0
添加一条评论
My left side just won't work anymore..
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
lukasgreicius70 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 8
过去 30 天: 17
总计 62,416
