跳转到主内容
型号 A1213或A1218,闪存容量:8、16及32GB
216 个问题 查看全部
turns on to apple screen, then off, then on...
When I turn the ipod on there is an apple. It turns off after several seconds, then back on, then off, etc. I read a post that there was a boot file to download from itunes. Does anyone know what file this is?
Or, are there other possible solutions to fix this problem?
This ipod had water damage and was not working previously. After cleaning the logic board I got it to this point.
Thanks for any advice!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
已选择的解决方案
First hold down the home button & sleep button until the apple appears. Let go of the sleep button (but keep the home button pressed down) till the apple disappears. Let go. It should show the connect to itunes screen shortly. Connect to itunes and do a restore. If that doesn't work double check the battery connections and place tape over the soldered portion of the wires, to be sure they aren't coming in contact with the case or each other. If that still doesn't seem to work, perhaps the battery is dead/ almost dead so you may want to leave it to charge for an hour or so before trying to reset it again. Good luck!
P.S. These are just some of the fixes that have helped me, I'm sorry I never heard about a boot file on iTunes.
这个答案有帮助吗?
得分 3
添加一条评论
The Byky's procedure worked for me but doing the IPOD restore on another computer.
这个答案有帮助吗?
得分 1
添加一条评论
100% Guarantee -
WORKS EVERY TIME- FIXES EVERY IPHONE…
All you have to do,
1) Fill a pickle jar of YOUR OWN (it can't be someone else's) !#^&
2) Drop the phone in the pickle jar -its important the !#^& has to be over 112ºF for this to work so you might need to microwave it for 1minute no more then 2minutes
3) Drink the !#^& fully naked, while recoding and play with your private parts
4) Send the video to a few Congress men, make sure in the email you mention you had a elementary school P.E teacher that was born with both a weiner and a vagina and that the P.E teacher use to molest you under the parachute, every time you played with the parachute in gym class…
If your school didn't use or even havea parachute in gym class, it won't work…
You can Just keep try the 4 step process upto it wont take more three attempts but send the recordings of each of those attempt to any of the Chinese Embassies in America , mention your brain don't work too well without your phone
If you do that.
VOILA !!!
YOU GOT A BRAND NEW PHONE COMING TO YOU ASAP
IT WORKED FOR ME -!!
I sold the old phone $100 to some idoit, that was going to waste time to fix a phone I repeatedly dropped in !#^&
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Garry 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 18
总计 6,353
