跳转到主内容
The Alcatel One Touch Idol 3 features a 5.5-inch, 1080 x 1920 display powered by a 1.5 GHz processor. Released in June 2015. Models 6045Y, 6045K, 6045O, 6045I.
Why won't my new phone start?
Dear all,
I just bought a new One Touch Idol 3, and after approximately 6 hours of charging (with the original charger) nothing happens when I try to start the device. Hard reset (power + volume up) etc. hasn't produced anything either. Suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论:
cant open my alcatel one touch idol3...
完成的
Hola mi alcatel pop no enciende, pero todo el tiempo tiene encendido el LED indicador de carga, aunque no se este cargando la batería. Saludos!
完成的
添加一条评论
1个答案
AFAIK, the very first boot (white animation + phone temperature rising noticeably) may take up to an incredible 10-15 minutes delay. Be patient and, meanwhile, connect the power supply. If nothing new happens after 15 minutes, then return the phone for repair.
Please note - here, I'm only talking about the 5.5" version (aka TCL-6045). The 4.7" may behave differently.
这个答案有帮助吗?
得分 0
1条评论:
My phone wouldn't turn on, but your suggestion of hard reset solved my problem, thank you so much! I think I downloaded something that messed with the software booting up properly, since I can't think of anything physical I did wrong to it.
完成的
添加一条评论
添加你的答案
Kevin Boots 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 5
总计 1,993
