跳转到主内容
加入维修社区 - 创建账户
型号A1367,闪存容量:8、16、32及64GB
iPod hasn't been able to turn on
I opened up my 4th gen iPod to fix a jammed lock/sleep button. I had turned it off before working on it as a safety measure. Now I haven't been able to turn it on. Even if I connect it to iTunes the screen doesn't light up.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
I have an ipod touch and for some reason I have left it on charge for hours and then I treyed to turn it on and it wont turn on for no reason
完成的
添加一条评论
2个答案
Hey Kathy,
So iPod TG4's are infamous for being finicky devices, the first thing I would try is to bridge the connection between the metal on the bottom of the charger port to the positive battery terminal. Often times this will bring them back to life. If that does not work let me know and I would be happy to help you further!
PS make sure you scrape off the covering over the solder connection on the battery terminal
这个答案有帮助吗?
得分 0
3条评论:
Is there a more simpler way to solve this problem?
完成的
Not that I know of however I have seen many of them come back to life after said reset.
完成的
After many a try I could not get it to turn on. Any other suggestions?
完成的
添加一条评论
my ipod has that blank screen too but my home button is completely broken..my screen has been like this for two days now and its weird how when i charge it i hear the charge sound i jus dont know what to do to get the thing on
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
kathy 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 34
总计 282
