跳转到主内容
The Inspiron 15-3521 has an optional touch screen feature and has a 15.6" display. This laptop is also complete with a matte finish and keyboard complete with number pad.
Why can't I install the usb driver?
After installing windows 10 there were a couple missing drivers. I troubleshooted the laptop in devices and printers and it fixed all the driver issues except for the USB2.0-CWR driver. It says it doesn't have it. I tried to update it from device manager but it says windows can't find the driver, go to the manufacturersame website. I couldn't find it on dell.com either. What should I do?
It says in properties that the drivers for this device are not installed. (Code 28)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
have you updated windows 10 yet it could help
完成的
I'll try that thanx.
完成的
Ran a bunch of updates. Didn't change it. I had a problem on an hp pavilion recently where it didn't recognize the DVD drive. It seemed like a driver problem but was actually something in the registry that needed deleted and then it worked fine. Could this be something similar?
完成的
添加一条评论
4个答案
已选择的解决方案
Hi,
Did you try this link, scroll to bottom and download Realtek USB 2.0 card reader?
http://www.driverscape.com/manufacturers.... If you have please ignore.
这个答案有帮助吗?
得分 2
1条评论:
Thanks, Jayeff, your link worked great.
完成的
添加一条评论
down load driver genius it should find the driver.
这个答案有帮助吗?
得分 0
添加一条评论
Hey! It is easy! If you can't download drivers from official website, you can try to use a 3rd-party driver program to download driver for Windows 10. More detail: http://goo.gl/5h6ICN
这个答案有帮助吗?
得分 0
添加一条评论
maybe you should look for the driver Sesua, try visiting http://www.aiydriver.com and find your laptop drivers
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jesse 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 1,698
