跳转到主内容
The Toshiba Excite 7c is a tablet released by Toshiba in 2013. It is a 7 inch black tablet with a white or gold back, front facing camera, SD card and micro USB slots.
3 个问题 查看全部
Battery does not last as long as it used to
My tablet used to have a battery life of 10-12 hours without needing a recharge. Now I am lucky for it to last for just an afternoon. What might be some possible causes and solutions?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
drain the battery then put it in the freezer 8-10 hours.. Place it back in the machine and charge it to full capacity. If that doesn't work, get a new battery.
完成的
I know the manufacturer says not to do this but they only want to sell more batteries.
完成的
添加一条评论
1个答案
已选择的解决方案
Looks like this is an older tablet, as with any battery powered device the batteries do wear out over time. The battery in this is Lithium Ion technology. Lithium Ion batteries have a limited amount of charge/discharge cycles before they start losing capacity. You might want to look into replacing the battery, I unfortunately couldn't find one with a quick search but here is a guide on how to replace it: Toshiba Excite 7c Battery Replacement
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Adam Burdzel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 138
