跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1624 个问题 查看全部
问题已关闭
Why can't I transfer from External HD to Mac?
Hello. My Macbook Pro Mid 2012 13" can’t read my files from my external hard drive (WD My Passport Ultra 1TB) neither can I transfer from external to Mac. I’ll attach here the message from the laptop when I try to open it. The format is on MAC Extended (Journaled). I opened the external using TransMac from Windows 3 days ago but I really did not open any of the files I just checked if they are still in the external. D:
Here's the link for the "message" https://drive.google.com/file/d/0B1sB4SP...
MacBook Pro, OS X Yosemite (10.10.5)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Remove the damaged .jpg file, put it in the trash and empty .
这个答案有帮助吗?
得分 1
2条评论:
How to I find the damaged. jpg file?
完成的
Do a search for the first five or six numbers of the file name you posted.
完成的
添加一条评论
The format orientation must have been altered wen u connected wt a Windows PC. The best format that works for Windows and Mac is "ex-fat" u may try a recovery software to recover ur files if u need them so badly, then u should reformat the external disk to "ex-fat" before using on Windows or Mac
这个答案有帮助吗?
得分 0
添加一条评论
The problem is the format .You must reformat the HD to “exfat” before using it on Mac. However to recover any important files before formatting your HD, take the help of a file recovery software.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 131
