跳转到主内容
Aspire 5315 Series features Intel Celeron mobile processor and Mobile Intel GL960 Express Chipset
Why doesn't my laptop start up?
Cannot turn on my computer!
Hi!
Cannot turn on this laptop.
If I plug it in with battery in - status LEDs are indicated as:
Power/Suspend LED - lights up red;
Battery Charge/Discharge LED - bliks red;
If I plug it in with battery out - status LEDs are off;
When I try to turn computer on in both cases Power/Suspend LED turns on green for a half second as soon as I release the power button and I can hear as ventilator span on, but after half second it all turns down and returns to previous positions.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Having the same challenge with my acer laptop. What's the issue with acer gadgets?
完成的
添加一条评论
3个答案
After looking into this a little bit, here's the first thing I would try.
Remove the battery from the laptop, and unplug the AC power cable from the laptop.
Hold down the power button on the laptop for 1 minute, and then let go.
Reinstall the battery, and plug the laptop into AC power.
Try to start laptop now.
这个答案有帮助吗?
得分 0
1条评论:
Hi Greg,
I tried your solution, but unfortunately it didn't help, the laptop still won't start up.
Ted
完成的
添加一条评论
Take your computer to a store, let the professionals to do the trick.
这个答案有帮助吗?
得分 0
添加一条评论
I Once I removed the image cable from my laptop and re-inserted it correctly, the laptop suddenly turned off completely and it does not turn on without battery or with battery,Even the charger does not turn on And it has no symptoms and is off
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ted Herba 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 417
