跳转到主内容
A lightweight and slim laptop released in October 2008 by Lenovo.
Why are my keyboard keys not responding?
The keyboard keys are not responsive when clicked. Keys are getting stuck or are broken.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hello,
It's an easy fix, when it comes to the keys. If the key is stuck, you can apply pressure to the button and it will return back to normal. But, if the key is broken then you can easily use a tool that has a a flat tip and go underneath the key and pop it out. The key will then come off and you can easily replace it with the new one. It's quite simple, you can just place the key in the empty spot and push it down and it should easily fall into place.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anthony 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 304
