跳转到主内容
加入维修社区 - 创建账户
Sony Xperia Z3 Compact released in Sep. 2014.
Lower Loudspeaker doesn't work
Hi there, after the LCD replacement the lower loudspeaker seems not working anymore (also if replaced, so I think the problem is not the speaker itself but maybe is missing the connection between it and the MOBO). How is it connected to the MOBO? Maybe trough the black plastic bezel which contains the screws? It is broken in the left side, it fits good but maybe this is the problem that cause the malfunction?
Waiting 4 your kind reply
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
Hi Maria
Did you solve the issue with lower speaker?
I have the same problem after replacing lcd
完成的
添加一条评论
2个答案
I will think the loudspeaker wasnt install correctly can you take a picture if you can.
这个答案有帮助吗?
得分 0
1条评论:
It is already installed in the replacements lcd I bought
完成的
添加一条评论
Hello. I know that I write after a long time I just would like your help.
I have the same problem with the bottom sound, after replacing the battery, and while I did not cause any damage, it does not work at all at the bottom.
Have you solved this problem?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Maria Aurora 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 16
总计 1,108
