跳转到主内容
Launched in October 2014, identified by model number CHDHA-301.
24 个问题 查看全部
How to fix a broken case?
I have the original GoPro hero and the attachment clips are part of the housing case which can't be replaced or removed. I was wondering if anyone had any ideas about how to reattach the clips? Is it going to have to be a glue job?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
2条评论
I have this problem too
完成的
The same here. Broke off in the water. :(
完成的
添加一条评论
2个答案
最有帮助的答案
Here is a great solution:
https://www.youtube.com/watch?v=qIk4T9J8...
这个答案有帮助吗?
得分 2
添加一条评论
The switched output board needs to be replaced. It could have just died, or burned out from trying to pull more than it is rated for.
这个答案有帮助吗?
得分 -1
1条评论:
That isn't related to the question.
完成的
添加一条评论
添加你的答案
James Roberts 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 8
过去 30 天: 33
总计 8,377
