Why does my GPS keep turning off?
My GPS keep turning off right after I turn it on. How do I make it stay on?
Try plugging in the GPS to see if it will stay on. If that does not work, check if the cable is working. You can test this by trying out a different cable. If the cable is not the problem, then you'll most likely need to replace the battery. Check out the replacement guide for more information on how to replace the battery.
这个答案有帮助吗?
Magellan suggested that I try charging the GPS on my computer for 6 hrs. When I connected the GPS to my Mac computer, the GPS turned itself off and on every 15 minutes, each time my Mac sent a notice: Disk not ejected properly.
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 2,312
