跳转到主内容
The Motorola Droid (model number: A855) is a full keyboard touchscreen smartphone powered by Android.
33 个问题 查看全部
How do you re-adhere parts
I have a Droid that is water damaged (no screeen). Was thinking about a LCD replacement, but I'm curious how to re-adhere a lot of the parts that are held together with adhesive, you know, those little plastic exterior covers and such. Does everyone find that re-assembly does not require new adhesives? Does the adhesive that held the original parts together will work again just fine?
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Thanks. I appreciate the info.
完成的
添加一条评论
1个答案
已选择的解决方案
Some adhesives are re-usable and will stick well enough (tape on cables, small internal padding) but the adhesive to hold screens to digitizers or front panels, etc is usually replaced. I do not know if there are replacement strips available for the Droid, like there is for the iPhone. You may have to custom make your own out of double-sided tape.
Here is an example of iPhone adhesive strips:
[关联产品丢失或禁用: IF137-006]
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Buzz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 1,448
