Why wont my device charge when plugged in?
when i plug in my device it does not charge why is this?
My device want charge at all or it want come on at all need help please......
这个答案有帮助吗?
Hello,
I am getting nothing when trying to charge my cubby. The device won't even turn on. Thanks Jeffrey_Hemingway@yahoo,com
It is possible that you don't have the adapter fully in the charging port or it is possible your charging port may need replacement. Before attempting to replace your charging port check to see if the cable & adapter will charge another device it is possible it is a faulty cord or adapter
这个答案有帮助吗?
I found a battery wire that is soldered to one of the three pads on the main board was not connected they felt tight but were being held in place by the plastic insulation. I stripped back the insulation(about 1/16 inch) and resoldered the connection
这个答案有帮助吗?
maybe its your cable not working probably, i suggest you get a new one. I reckon it won't be too pricy
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 1,723
