跳转到主内容
The Garmin Nuvi 1300 is a GPS unit with a 4.3-inch screen. It is also known by its model number, 1300T.
9 个问题 查看全部
Can you replace the battery easily?
The battery in my Nuvi barely lasts any time at all and with a finicky charger, this means it will tend to quit in the middle of a trip. I was able to sort of see the battery in the disassembly guide, but I was wondering if the connection is soldered on or if I could open it up and get a replacement, possibly even a bigger one. Anyone happen to know?
I only use it for long trips now where I want to conserve my battery on my phone so I may just bust it open and see anyway.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Firstly, these devices are generally not meant to be serviced by consumers. That being said I have recently taken apart my Garmin Nuvi and found that the battery leads (colored wires) are soldered to the board. It is still possible to replace the battery but it will be more difficult and poses more risks than one that uses a connector.
这个答案有帮助吗?
得分 4
添加一条评论
最有帮助的答案
If you want to try opening it here's a guild that shows how to open without breaking it
Removing the Garmin Nuvi 1300 LCD touch Screen assembly
this guild is for replacing the screen but does get you into the battery. Hope it helps
这个答案有帮助吗?
得分 5
添加一条评论
添加你的答案
addamxavier 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 8
总计 1,643
