跳转到主内容
Repair and support information for HP Laptops, designed for home and home office use.
964 个问题 查看全部
Keyboard not working after water spill
I spilled about a qaurter of a cup on my numbad on my right side of the laptop, i dried out 90 per ent of the water, flipped the laptop, left it for 5 hours, i open it, everything works a-okay, but after 30 mins to 1 hour, the keyboard stops working completely, i shut the pc down, restart it, it works but same thing again after an hour, and it keeps loopong..... all this happened today, and i need help with it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
Funny this was posted 3 years ago and never got an answer to it. Thanks for the answer though.
完成的
添加一条评论
3个答案
最有帮助的答案
It sounds like either the keyboard has gone bad due to water or the motherboard has short circuited due to the water damage. Try connecting a USB keyboard and see if that works, if not it is more than likely the motherboard.
这个答案有帮助吗?
得分 3
1条评论:
Problem is, i dont have a keyboard. Plus in 14 years old, and if my dad knew about this !&&* ban me from the pc, so i cant buy another one.. but i left it to dry some more, and it did the same thing but worked 5 minutes after breaking, so i immediately left it to dry in false hope it would fix itself, but a usb mouse and an audio jack headphone work perfectly, if you can respond that would be amazing, and thank you for paying me attention.
完成的
添加一条评论
I also am experiencing a spill problem. Spilled Febreze and rubbing alcohol on it, only a small amount, its completely unresponsive. Down to using onscreen keyboard. HP Pavilion 17, Thank goodness it still boots to desktop. Looking into getting usb keyboard.
这个答案有帮助吗?
得分 0
添加一条评论
So if I understand this correctly water got into the keyboard and now it doesn’t work. First thing I would do like somebody else mentioned is connect up a usb keyboard and see if it will respond to that, then make sure that the trackpad (how you move the mouse) is still functional if that is still functional then really all you need to do is replace the keyboard which depending on the model should not be that hard.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gaming phantom 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 51
总计 15,183
