跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Can the information or memory of a spoiled iPhone 5 be retrieved
My iPhone 5 just went off all of a sudden.
Took it to a repairer but still isn't coming on he says the board is spoiled and cant work again.
I have a lot of information on this phone is there anyway I could retrieve my information back like pictures and whatsapp messages??
Can a part of it containing these information be taken out and put into another ??
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
so even if i change the logic board i wont get my info back?
完成的
添加一条评论
2个答案
已选择的解决方案
Sadly no, You may have some of your info saved within your iCloud account.
The problem here is the flash is encrypted and the chip is soldered onto the logic board and not removable.
这个答案有帮助吗?
得分 2
添加一条评论
If you have icloud backup enabled, you can just restore the backup on a new phone. All data on your stock apps can be restored, for 3rd party apps, data is also backed up in most cases.
If Icloud wasn't turned on. You'll have to repair the board to bring your data back. The CPU and flash memory must not be changed as they are paired and use device-specific keys to encrypt the content. If the flash memory is dead, of course you don't get your data back. But if the CPU is dead, even if the flash memory is working, you cannot decrypt the files dumped from the chip.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
kaysi ainuson 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 90
