跳转到主内容
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
152 个问题 查看全部
问题已关闭
No Plastic flap on SIM/Front Facing Camera - how to fix?
Hey guys,
i bought a defective iPad 2 on ebay but the guy who owned it before seems to have used wrong tools.
There is no "plastic flap" which holds the cable in its place anymore - so the cable is not able to make contact..
Foto of Plastic Flap (c) by iFixIt
(The black small "flap" is missing)
As a workaround I put a small piece of paper under the cable - now it works partially - front facing camera works, SIM is still not recognized. But I want a bulletproof solution ;-)
What should I do to fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Order this and remove the black plastic tab and manually install it on your ipad http://www.ebay.com/itm/2-PCS-FPC-SMD-Di...
这个答案有帮助吗?
得分 1
1条评论:
Ha!! Great! Thanks!
Could you confirm this is the same item
http://www.ebay.de/itm/iPad-2-3-4-Digiti...
Going through this should do it, right?
https://www.youtube.com/watch?v=U6T01c64...
Thanks for your quick reply!!
Jonas
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 52
