跳转到主内容
加入维修社区 - 创建账户
Repair guides and troubleshooting for the Acer Aspire 5, a series of laptops on the Windows OS by Acer.
Laptop won't turn on or charge.
So my laptop was on about 10% and so i plug the charger when i plugged the charger the laptop turned off itself and wont even charge. it was perfectly working last night and i dont know whats the problem..someone help me what to do?
Model: Acer Aspire V5-431
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
添加一条评论
4个答案
If you have another charger lying around try it. Sounds like the charger may have malfuntioned.
这个答案有帮助吗?
得分 0
添加一条评论
Hi. Disconnect the charger. Now take out the battery and plug the charger back in. See if the laptop will now boot from the charger. If it does, then you need to buy a new battery. Don't run the laptop for too long from just the charger as it can damage the charger.
这个答案有帮助吗?
得分 0
3条评论:
My laptop won't turn on but it's still charging. What should I do?
Model: Aspire V5-132P
完成的
my laptop stil doesnt boot from my charger.
I even tried other working chargers.
完成的
I had this same issue so I took out the battery and plugged the charge in and it work. I then turned my computer back off, unplugged it and put the batter back on. Once the battery was back on I plugged the charger back in and my computer works fine. Does that till mean I need a new battery?
完成的
添加一条评论
Maybe the motherboard got short circuit.
这个答案有帮助吗?
得分 0
2条评论:
why would plugging in the charger short circuit the motherboard??
I ask because exactly the same thing happened to me, and no amount of suggestions and nothing I did made it turn on again. I gave up and sadly it remains gone. But was the issue with the charger? or a faulty circuit? or something else???
完成的
If it was a charger for a different laptop that you tried, then you could possibly damage the charger or the laptop motherboard. If the laptop appears to be charging but there is no picture when you try and start it, try connecting to an external monitor. Most laptops have a VGA output port, some have an HDMI port as well. If you get a picture on the monitor then either the laptop is set to display externally which is just a keyboard setting or there's a problem with the motherboard. If its the latter, then you will need the services of a repair shop.
完成的
添加一条评论
hi
sorry but your laptop need to open and fix problem in input .so you should go to fix shop
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tashia Holland 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 23
总计 8,184
