跳转到主内容
加入维修社区 - 创建账户
The Lenovo Tab 2 A8, model A8-50, is an Android-based tablet released in April 2014. You may see model A5500-F in fine print on the back (distinct from earlier A5500 model)
My tablet won't charge at allor turn on.
hi, i just bought a new Lenovo Tab A8 from office depot, i got it for 15% less cuz they didn't have the charger. they said i could use my micro USB as same as my android phone. but now it won't charge at all, it shows battery drained sign, but never starts charging at all. i tried it with different micro usb chargers but no go.
any idea on how i can fix it without spending money please
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
4个答案
已选择的解决方案
Hi,
Ensure that your charger is 5V 2A (2000mA) output. Phone chargers may not supply enough current.
If using correct output value charger and battery drained sign still there, Press the Reset button behind the micro SD card slot cover, Hopefully it will then start to charge.
Allow tab to fully charge before turning on, then long-press the power key for over 10 seconds to restart
这个答案有帮助吗?
得分 3
添加一条评论
Also check out these guides!
How to Hard Reset the Lenovo A8
Lenovo Tab 2 A8 Battery Replacement
Lenovo Tab 2 A8 Battery图片
指南
难度:
简单
10 minutes
Lenovo Tab 2 A8图片
指南
难度:
非常容易
20 seconds
这个答案有帮助吗?
得分 0
添加一条评论
my tablet cant turn on and have lost all the data
这个答案有帮助吗?
得分 0
添加一条评论
hey. . i have a problem with my levono tablet . . the tablet works fines but the charging system isn't working at all . i tired using other cable chargers but still it wont charge and my tablet hasn't been in use for some days now and hoped you could help me fix it please . . . .
这个答案有帮助吗?
得分 0
1条评论:
Hi,
Check the charge port with a strong light and a magnifying glass to ensure that all the pins are there, that they are straight and parallel with each other and that the port enclosure is free from dust and lint.
If there is lint trapped in the port, use a vacuum cleaner to try and suck it out. Do not use a metal probe. If necessary, use a wooden toothpick to 'gently' try to remove it.
If it looks OK, try the following:
Take the tablet end of the charge cable and plug it into the tablet. DO NOT connect the other end of the cable to anything.
Then holding the tablet firmly, grab hold of the plug which is inserted into the charge port and try to gently, stress gently move it from side to side or up and down to check if you can feel any movement at all in the USB connector.
If you can detect movement, then the USB connector may have become disconnected from the systemboard.
Here is a link to the ifixit USB replacement guide which may be of some help.
完成的
添加一条评论
添加你的答案
Quincy Murphen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 15,558
